Seat cover
firerage101
I'm not sure if this goes here, but i purchased my truck with a burn mark in the lower seat cover (gray in appearance cloth) anyways i spoke to the dealer and they said i could obtain a cover for this to replace it, or just replace the panel. The problem i have is they dont want to tackle this problem and repair it or deal with removing the cover. I also seem to be having a hard time finding the right material to repair this cover with, any suggestions.
We sublet all that kind of work to a local trim shop that does an excellent job. Look in the yellow pages for upholstery repair shops.
I appreciate it, we have only one slight problem, im 3 1/2 hours to a reputable shop. I'll have to try Canada and see what they offer. Also if i have a warranty issue with a vehicle can i take it to a canadian dealer or do i have to use a U.S Dealer
All I can tell you is that if a Canadian TOURIST comes to our dealership, we can do warranty work. I would guess the same applies to a U.S. visitor in Canada.
I'll make a point to claim im a tourist
