transmission "issue"
Ok, so I park the truck Saturday night after work, no problem. Don't drive it at all Sunday. Monday midmorning I figure it's time to start Christmas shopping, so I start the truck, pull it out of park, and... the lever won't go past neutral. WTF? Reverse works. I keep fiddling with it (gently) and it finally goes into drive, but no lower. I go to the mall, and when I get there te lever moves as it should through all gear selections. It then did it later last night when I went out, but not as bad. Again, once everything warmed up, it was fine. I'm hoping something got some water on it and it froze, but I'm wondering if anyone else has had this issue before.
Truck is a '04 2500HD with the 6.0
Could be the solenoid (?) that engages when you put your foot on the brake pedal. It's supposed to only permit you to move the selector when you have your foot on the brake. Next time it happens, try tapping the brake pedal to energize the solenoid over and over, see if it helps loosen it up for the moment.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 906 Guests (See full list)
