engine stalls
Hello all,
Haven't been on here for a while, did use to vist frequently.
I'm on my 4th truck now, my second silverado 4x4, first was a 1999, now have a 2003 pewter Silverado LT, Z71 4x4 extended cab.
I have an ARE cap with the full fiberglass door so I have removed my tailgate, therefore haven't done the tailgate cable upgrade, since my dealer refused to give me the cables since they couldn't do the labor.
I have however had a dealer do the stearing linkage recall, to remove the clunking noise, this worked.
I do have the drivetrain (freeplay) intermittent clunk, which I understand GM has no fix for yet (and may never) and says it's normal. I have learned to live with this.
But I now have what may be an unusual problem that has been appearing for the last month or so? It seems to mostly occure when I am at low speed and turning right? My engine will stall, acts as if it is out of gas, sudden stop? but restarts easily? it will stall multiple times a day(sometimes 4-5), reqardless of wether it's warm or cold.
I was wondering if anyone has any thoughts or info on this, also I looked in my owners manual, and can't find any info on where the diagnostic port is on this truck. I assume it would be an OBDII. The local Advanced auto parts down the block from me has the I believe Acutron diagnostics tools you can use free in their parking lot. I don't have a maintenance manual, Clymer/Haynes etc yet since I can't seem to find it anywhere, didn't want to pop for the OEM manual due to the cost, but may have too.
I did try search first as well as ask the GM Tech, under various stalling topics, and couldn't find anthing related.
I wanted to try and figure this out on my own, with your help, before resorting to a dealer if possible.
Thank you in advance, for any help.
OK have been doing some reading here, seems some areas to check are:
(1)Fuel pressure regulator.
(2)EGR valve cleaning?
(3)Mass flow sensor (not sure)
(4)gass pedal return springs
A few on the board have had success with a simple complete cleaning of the throttle body. Guys were finding carbon blocking up the air bleeds, etc...
Get some cleaner, and start spraying. It should work. Get everything spotless.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,157 Guests (See full list)
