Rear end noise
srlbotanical
I drive a 97 1500 4x4 silvy 5.7L with the limited slip rear end.
When coasting at about 15-20 MPH I can hear a very faint repetitive noise coming from the rear end. It sounds like "wha, wha, wha, wha," but so faint that only I seem to hear it.
Now, when I coast around a corner at about 15 MPH it gets louder, but a passanger will not notice it unless I point it out and make them listen closely. I have pulled the back wheels and the brakes are in good shape, I don't notice any fluid leaking from around the seals or anything out of the ordinary.
Am I looking at a shaft bearing problem, or somthing else? :)
Thanks,
Steve
If the noise changes when you go around a corner, it's unlikely it's a side bearing in the diff. More likely an axle bearing, though weight shifts don't usually change the noise much.
Thanks,
Steve
First of all, make d**n sure you are not hearing any type of tire noise.
Second, when was the last time you changed the rear differential fluid? I'd go ahead and chang it, and also remember to buy the posi-additive from GM.
If none of these tips help, I would say possible a bad pinion bearing? or worn ring and pinion gears? Very tough to tell when you can't hear something in person.
Thanks Guys, I'll change out diff oil first and see what happens. I know its not tire noise, thats the first thing I thought of. I even got in the bed and had my wife drive around so I could hear it better. The only problem was, she didn't drive it exactly the way I wanted, and I ended up having to make my own dinner...
Go figure... :)
    appletrav
    appletrav
  • Who's Online   5 Members, 0 Anonymous, 288 Guests (See full list)
