IPOD Question
Halen5150
I have a newer Pioneer Premier head unit. Best buy sells an interface for $120 that supposedly lets you control the ipod from your head unit. Does anyone have any experience with operating this? I need to know if I can use my pioneer remote to control the functions on the ipod, and how well it works. I was also wondering if the song title of the mp3(stored on the ipod) will scroll across the display of the pioneer head unit, like it would on a cd. Thanks in advance for any help.
I would suggest taking the interface's model number and doing a google search, such as "CD-IB100 review" .
Weed through all the results and after some digging, you should find a suitable review that might answer your questions.
Secondly, if you can't really get an answer, purchase the unit from Best Buy. If you don't like it, simply return it for a refund. I'll bet a lot of folks here try things out and then return them.
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 484 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
