99 GMC 2500 7.4 PICKUP- part 2
RACECAR
Another question i have besides the engine number is i am trying to get it to pass emissions which it failed with high hcs bad , so tuned it up plugs cap rotor wires air filter all GM going to change oil tryed to retard the timing , found that won't work on these 454s had a scanner on it i was i believe in range this engine runs perfect except for a small skip while it is idleing no hesitation when you press the pedal at any speed does not smell rich while at idle it is a 5 spd will look for all the vacuum lines i think this is a replacement motor the truck has 177000 this thing runs to good for a 177000 mile engine any hints on the high hcs and the slight skip at idle? Thanks.
Does it have the original o2 sensors?  That'd be the first place I'd go if you want to guess.
Thanks for checking the number, if this has 2 o2 sensors i better get my book out and figure out what they do thanks.
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 234 Guests (See full list)
