MSD Wires?
Mine were 75 american, 85 with s&h
Yikes...thats pretty steep. I just installed a set of Crane Firewires...25 ohms. They cost $45 shipped from Summit Racing...
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
