torque specs for 502 big block
454ss
i am rebuilding a 2001 502 crate engine back to stock specs. this is the "502 tow" version with non-adjustable valve train and roller cam, i would imagine the specs are the same as the 2000 454 but i dont have those specs either. please advise if you can, thanks. i need the torque specs for : rod bolts, main caps, head bolts, and anything else that would be differant than the old 70s 396-454 that i am familiar with rebuilding.
I sent them to you in a PM. Let me know if you didn't get them.
Doug
thanks for trying, but the attachment didnt go through. but i am talking about a 502 8.2l old style big block gm crate motor, not a new 496 8.1l. thanks for trying to help though. the 496 specs would also be nice to have though.
Oh.... I don't have them for the 502 and I'm not even sure where to look....
If you still want the 8.1 specs send me a PM with your email and I will try emailing them to you...
Doug
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 256 Guests (See full list)
