Idle Fluctuating on an 03 5.3 Silverado
XPBri
Well, I just became the owner of a "new to me" 2003 1500 Silverado 5.3 with 73K on the odometer. The truck was previosly driven all highway miles.
Now for my dilemna. The truck has a fairly low idle of 500 RPM, the truck fluctuates from this RPM when at idle. I've checked the normal causes- there are 0 air leaks, also the intake gaskets have allready been replaced. Has anyone experienced this problem before? Well thanks for reading through this.
Thanks,
Brian
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
