2000 GMC yukon engine knocking?
Over the past few months, I have noticed that if my Yukon has not been started for more than a day or so it will make knocking noises for approx. 10-20 seconds.
Has anyone experienced this problem beforE?
You betcha,
Take solace in the fact that it goes away after 20 seconds. My last ford did it all the time.
Ken
my work truck, 2001 Sierra with the 4.8 knocks pretty well after cold start up for about 15-20 seconds, it also has a warm idle knock as well.
The 4.8 and 5.3 do knock alot. Knock on wood.:crazy:
To be honest, I think it's normal to expect knock out of any V-8 engine. Now I know some on here will say they have never had a knock issue before and that may be true, but I've seen Fords, Dodges, Chevys, even Toyotas and Hondas that knock.
  • 9 months later...
Sorry to bring this back up:
my engine knocking is about the same, but ever since winter has started this year if I accelerate hard within say 10 minutes of start up you still get some slight knocking.
Is this something to worry about, should I have it looked at? Last thing I want to do is blow a piston.
also, its a 5.3 L with about 120k miles
I would have thought that after letting it sit for a few days, then it only doing it for the first 15-20 sec after starting that it would just be your rockers knocking until oil pressure built up bathed them in oil. This could not be a problem anymore or I could be nuts, but that is how I always could tell that the 92 suburban that I used to drive was low on oil... you'd hear the rockers knocking.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,300 Guests (See full list)
