Navigation & DVD in 2007 Yukon / Tahoe
I am planning to order a 2007 Tahoe or Yukon. I want the Navigation Radio upgrade. I also want to have DVD playback capability. I would repfer to not have the "factory" drop down LCD screen, but instead have a monitor installed in each headrest.
How can I do this?
Also, am I to understand that the Nav radio only has 1 slot? Can I also hook up an external CD/DVD changer?
Thanks!
Ryan
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 213 Guests (See full list)
