bearings going bad?
I have a 2001 Tahoe 5.3 w/ 120,000 miles on it. I have been running Amsoil since I bought it at 56,000 miles. I recently did an oil analysis and it detected high levels of copper and aluminum. Copper was 273ppm and aluminum was 12. several friends are telling me that my bearings are going and my 5.3 is not long for this world. Any opinions on this?
If they are going, any recommendations on where to pick up a remanufactured 5.3?
Thanks
Thanks
How about http://www.jasperengines.com/
But I wouldn't just take your friends word for it. How's it run other wise? I'd get a couple of more oil analysis done before I started to worry.
I agree with norseman. I wouldn't worry just yet. There was a link to a semi-scientific oil study on here a few months back. I say semi because it wasn't a controlled test and the conditions between the tests obviously varied.
http://neptune.spacebears.com/cars/stories/oil-life.html
The guy that was running this apparently ran into the same issue with high copper counts in the oil. For good or bad though, their test with AMSOIL didn't seem to fare as well as off-the-shelf Mobil1. I am currently using the AMSOIL in both my truck and SSR. I had been using Mobil1 in the truck from the first oil change I performed at around 5k miles, so it's seen nothing but synthetic since the initial break-in. However, I don't plan to, nor have I ever, run oil in my vehicles for as long as they did.
At 120k, that engine's "just broken in" as some would say. Unless it was abused by a former owner, it should be good and strong up to 200k with proper maintenance.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
