'94 GM 1/2 ton, front axle ?
RI1994
I'm doing a 4" lift kit in my PU and I ended up buying new axles because my old ones werand e shot. I also installed new oil seals in my spindles. My question is, " How much resistance should there be when the hub is bolted to the spindle and the axle is through the hub and tightened down with the big nut?" How easy should the axle spin and how should the axle line up with the seal in the spindle? Should it be flush or should it protrude a little bit?
    Aries68
    Aries68
  • Who's Online   4 Members, 0 Anonymous, 413 Guests (See full list)
