rattle on 04 burb driver side frt
On my o4 burb 4X4 I have a dull rattle that I feel in the steering wheel. Sounds like a loose shock but everything seems tight. Ive heard of this before from a Tahoe owner also. Any takers on this one. Seems more when turning left, and going slow over bumpy ground.
Scott
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
