2001 Denali Need Help with Bose
I have a 2001 Yukon denali and I want to add two JL audio 10" subs and an amp to this system. I have tried absolutely every thing I can think of and can't get the new subs to work. I purchased a PAC AOEM-21A but I cannot figure out where to connect it. It appears that the bose amp is in the rear drivers side panel but the PAC device pins are different. I've heard that the PAC is supposed to connect underneath the center console??? Can someone PLEASE help me figure out where the PAC is supposed to connect????
THANKS for your help....
I bought a PAC adaptor for my 04 (non-Bose) and it plugged between the factory radio and factory harness. You plugged the factory harness into the PAC and plugged the PAC connector into the back of the stock radio.
    rayredbone
    rayredbone
  • Who's Online   2 Members, 0 Anonymous, 429 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
