1991 Kodiak
I just bought a 1991 Kodiak. Does anyone know is the radio out of a 1/2 ton fit in this truck?? I was just wondering because I was looking on ebay for one and found one for the kodiak and it is cheap looking ( sliding volume knob) . But I would like to have the digital one if it will fit?????
I don't see why it wouldn't. As far as the dash goes, the parts should fit. I can't say on the wiring though. The digital radio (if I remember properly) is a 2 piece unit. The digital dislpay/ buttons is mainly just the display. The other part of the radio mounts further to the right near the center air vents. Some also have an equalizer (and tape deck?) that mounts directly below the center air vent as well.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
