1997 Delco Radio Theftlock
yukonGT
I have a 1997 Yukon GT, and purchased another Delco 09354155 radio, just like what came in my 1997. Half of the original radios night time illumination didn't work and thought the economical way was to buy a used one off ebay. How do I reset the theftcode on the new radio? How can I disable the theftcode on the old one before I remove it?
Thanks...John
Is it locked now?
The radio that is currently in the truck is NOT locked, I was told the radio that is on it's way is locked.
If it shows up locked the best thing to do is take it to you local dealer. They will unlock it for .5 to 1 hour labor. They will get a 6 digit number from the radio and call it in with the dealer ID to get the unlock code.
John: I did the exact same thing for my 98. When I installed the new stereo, the display just said LOC and I had no codes. I found this in the forums using the search function. It worked great for me. I don't know who the original author was.
Theftloc Bypass
1. Press and hold presets 2 & 3 for about 10 seconds until the first 3 digits of the display code are displayed
2. Write the numbers down.
3. Press the AM FM button, write down the next 3 numbers
4. Call 1-800-537-5140, when asked, enter 139010*, when asked enter the 4 or 6 digit code (obtained from Steps 1-3) from the radio and an *, for example using my code, 702712*, you will get an unlock code, write it down.
5. Go back to the car, press the HR button and set the first 2 numbers, then press minute button and set the next two last numbers, press AM FM button, SEC should be displayed, turn on radio
To remove customers code, repeat step 5. you should see --- on radio face, the code is now out of the radio.
Good Luck
Denis
wow...thanks!!!!
Theftloc Bypass
Good Luck
Denis
    appletrav
    appletrav
  • Who's Online   4 Members, 0 Anonymous, 255 Guests (See full list)
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
