Quick Question
Is it alright to leave my speakers like this (pic only shows right side but the one on the left is the same) or should i have something covering them?
I dont see any reason that this will effect the sound or in any way hurt the speaker but a cover might help damage to speaker
They'll be fine as long as some nimrod passenger doesn't stick his finger in them.
Some speaker grills just block about 1/2 of the sunlight. Yours blocks none of the sunlight. So they'll fade faster, and you'll see the fade, and they might get brittle faster... probably will only last 1/2 as long.
Ok, ill try to park in the shade more often! Haha... they were only like $40 for the pair so i'm not like crazy about them or anything because the speakers by your ears (in the panels where the seat belt connects) are still stock because i cannot for the love of my life take off the panels without cracking them more then i already have. I wanted to replace them so i had 4 of these pioneers but i just couldnt get those panels off. Everyone just said "pop them out there is only little black clips holding them in" but i tried every different angle and every different way and they just wouldn't budge.
Here's the finished pics:
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,058 Guests (See full list)
