I need help finding a thread guys
Hey guys,
I hope everyone is doing okay. I was wondering if anybody could shoot me a link to the thread that went into major detail about the steering wheel controls being installed on a truck that didn't come with them from factory. I need the part numbers for the steering wheel and clockspring harness. My interior is dark charcoal, and so is my steering wheel. It's basically black. If someone could shoot me the thread and part numbers, I would be very appreciative!! Also, my truck is a 2005 Z-71. :banghead:
Thank-you,
Chad
Here's one.
I used this for my (Google) search criteria:
"steering wheel controls" site:gm-trucks.com/forums
BTW, I think there's a steering wheel/clockspring setup in the FS area here on the site.
Hey guys,
Thank-you,
Chad
JP Customs is working on a kit for the 03-06's to upgrade to steering wheel controls. You can do still do it but it's not plug and play. You have to take your truck to your dealership and have the tech guy call GM techline and get the new VCI numbers for the IPC and TBC.
http://www.gm-trucks.com/forums/index.php?...+wheel+controls
http://www.chevyavalanchefanclub.com/cafcn...9585.0/all.html
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
