Is a larger spare tire ok?
With less than 1,600 miles on my new truck, I managed to blow one of the tires. It wasn't able to be fixed, so I had the full size spare mounted where the blown tire was at.
Now, I don't have a spare, and all of the tire stores around here don't sell the correct tire size for anything less than $120, plus mounting. One place has an used tire I could buy for $30, but it is slightly larger. Would this be a problem?
Current tire size:
245/70 17
Used tire size
265/70 17
I don't see it being a problem, since most cars come with those ridiculous "donut spares", but I just wanted to make sure I wouldn't hurt anything.
And why doesn't Chevy offer a roadhazard program on the tires that come with new vehicles??? :banghead:
Current tire size:
245/70 17
Used tire size
265/70 17
If a 4x4, it is critical to keep the same tire size. Any difference in diameter can cause binding and breakage in 4/4 mode or rear diff locking situations. Different diameters also mess with abs programming and can trigger abs when driving normally. It really depends on the difference between the 2 tires.
I believe the donut spares are the same diameter as the original tires so they don't cause a problem. When I switched from P265/70R16 to LT265/75R16 tires, I replaced the spare for this reason.
Thanks.
The truck is a 2 wheel drive, non-locking differential.
Have you checked with your dealer? They will replace it in first year if there any good. I have had 3 replaced one a runflat.
I agree I believe the tires are covered by the Mfg.
I remember seeing the Bridgestone flyer in my pack of information in the glove box but have not read it yet :banghead:
*I also had a run flat go out on my C6 and it was replaced at no charge by Goodyear without an issue.
My dealer is a few hours away, so it wouldn't be worth driving there and back for a tire. I checked with the local dealer here in town, they wouldn't do anything about it, except offer to sell me a new tire.
One of the places I called earlier called me back, they found a correct size used tire after I had originally talked to them. I'm going to go get that one.
Thanks for everyone's advice.
It's my belief that the tires are not covered by the GM warranty, but but by the tire manufacturer. I had a Blow-Out on my '06 GMC (245/70/17) and General Tire has no Road Hazard warranty. I took it to Discount Tire, and they wouldn't touch it. I took it to another Discount tire (were I know someone) and they prorated it for me. Cost me a Lot less than a new tire. Guess what kind of tire I will never buy again - You got it - Generals.
As they add goes sooner or later you'll own Generals, well I own them, but never again.
Actually though, they are not a bad handling truck tire, but I will never buy another tire that doesn't have a road hazard warranty.
Lou
You mean there isnt a dealer closer than two hours away? Any dealer can replace it.
There's a dealer about 30 minutes from my home, and another one about 5 minutes from my work. Neither of them would replace the tire for free though, since it wasn't under warranty, and I didn't purchase the truck from them. The dealer I purchased from offers road hazard on the tires, but only if you get your oil changed there. I believe that they offer road hazard coverage for 3,500 miles after your oil change. They're pretty far from me though, and I had just changed the oil on my own, 2 days before the blowout, so that wasn't really a good option for me.
Yeah, I'm not overly thrilled with the General tires I have now. I'll probably pick up a good set of tires when the next snow season starts.
    CaptainDad
    CaptainDad
  • Who's Online   2 Members, 0 Anonymous, 624 Guests (See full list)
