Whirring fuel pump
My 2002 GMC is making a whirring sound; kind of like the sound a high speed electric motor makes.
It used to only do it after a long hard trip, but, now it seems to do it all the time.
I can turn on the ignition, and it whirs, then stops, but, as soon as you start it, the whirring comes back.
Is it normal to have such a loud fuel pump, or does it mean it's about to crap out on me?
I wouldn't say we had a lot, but a fair number of our fleet trucks have the whining fuel pump syndrome. Never have had any really fail. My '02 work truck started whining after about 10,000 miles. Just keep an eye (or ear I suppose) on the sound. If it makes a drastic change all of the sudden then you've probably got problems.
Change the fuel filter like suggested. The one time mine did temporary fail was when I unknowingly sucked up some crap from the bottom of the tank I got fuel at. It was 95 degrees, had 1/4 tank of gas, and I was driving slow on dirt roads with the AC on. Truck would sputter and die and wouldn't start unless I sat for 5 minutes. Then it would start and I'd be able to go another 5 miles or so and it would die again. I think what happened was the pump was working overtime with the filter being plugged and not much fuel in the tank around the pump itself to keep it cool. Changed the filter and it ran fine for another 25,000 miles before I turned it in at 75,000.
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 461 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
