2500HD model differences?
What are the component differences on the 2500HD models as far as towing goes? Is the suspension/brakes the same on the 6.0L v8 and it's bigger brothers? Is the main towing difference purely engine/transmission?
The trucks with the Vortec 6000 get an AAM 1050 rear axle, those with the Duramax Diesel or Vortec 8100 get an AAM 1150 rear axle. Both axles are rated by AAM for weights far higher than what GM publishes in their trucks specs.
Is the 1150 the reason for the 15k fifth wheel performance of the big blocks then? I know you'd need the engine but the 1150 can support the 25% of 16000lbs?
So far then, the transmission is better and the rear axle is different.
Anyone know if an additional transmission cooler can be added?
Thanks
Thanks
3500s get a taller body block, over load springs in the rear and 265 tires to handle the additional weight when loaded.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,058 Guests (See full list)
