Gas Kickout While gasing up
Hi guys.. i Have 04 2500HD, and everytime i try to fill it up the pump kicks out.
Is this a dirty valve at the Evap Canister?
If so where is this valve and where are the evap cans on these trucks?
Thanks guys.
is this only when it it is close to full or all the time?
My Burb spits back about a quart if I let the pump run until it auto shuts off. With gas prices getting up to $3+ this is starting to suck!
I have found the new trucks are VERY finickey to the angle of the nossle and how far in it goes. Try pulling it out just a little and make sure it is straight up and down, not twisted at all.
Thanks guys.
Same year, same problem! It doesn't matter how full or empty the tank is and pulling the fueling nozzle out doesn't help. It takes less than 10 seconds of fueling to kick out. I've got a guy coming over today to help me fix this so I'll let you know how it turns out. He says it is an easy fix that has to do with the lines running to the evap can. Apparently, a simple disconnect and cleaning with compressed air should take care of it. I'll keep you posted. Thanks.
Are you filling up at the same gas station every time? Some of the pump nozzles are super sensitive. Try pointing the gas nozzle in a different direction in the filler hole like on a 15 or 45 degree angle.
