Denali Suspension
Chaos600
I recently purchased a 01 Denali, and it has some sort of self leveling suspension or something, i have been looking into lowering kits and they say that i cant use the stock shocks, but i want to keep the self leveling feature, as i do plan on using my vehicle to tow trailers, is there anyway i can lower my denali, and retain the self leveling feature, even if i have to make a bracket or something
any help would be great.
How much do you want to lower it?
If you just want to drop the back a couple of inches, just move the auto-leveling sensor down a bit.
Those shocks are for thr ride control switch not auto leveling, my 02 Denali Sierra has the same, my wifes 03 Yukon Denali however has auto leveling like a hummer. You should be able to lower it with the torsion bars and some rear springs.
Dan
Dan
thanks for your help Dan, its just that i am a little confused, as far as self leveling and ride control, i dont know which i have, my shocks look like they have airbags attached to them and whenever i load a trailer or something, it wirrs and spins, and the back of the truck goes up, which do i have? thanks again, and it sounds like you got some pretty nice rides sitting in the drive, thanx again Dan
-Truman
Truman, I thought you had a pickup, you do have an air pump and auto leveling and it should be easy to lower the rig by turning out the torsion bar bolts in the front and adjusting the air ride control in the rear. I don't know if a new front end alignment is required when you lower the front?
Dan
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
