4l80e transmission
teamjnz
I recently installed some gauges to my 99' Suburban 6.5TD and one of them was a trans temp gauge. There are 2 lines on the passanger side of the transmission, 4L80e. One is closer to the bell housing and one is near the tail of the tranny. I was told the line near the rear is the line that goes from the tranny to the cooler. This is the line I installed my temp probe to read from. More recently I was told this is the return line from the cooler.
What line do I have the temp probe installed? :bs:
Thanks
Thanks
If memory serves, the "Front" line (meaning towards the front of the vehicle) is the "Return from Cooler" line... so for a trans temp, you would hook the gauge up to the Rear line (Trans to cooler).
Now, dont hold me to this, but I also have Logic backing this up.. cool fluid front to back flow.. Makes complete sense to me, but hey... Doesnt mean some braniac engineer defeated the gravity thing, ya kno? :flag:
-Gonz
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
