Want to do a 6.0 to 8.1 swap in 2001 2500HD 4x4
Ok, I have a 2001 2500HD 4x4 crew cab, want to put the heftier 8.1L into her for more power, what is involved? I am after, and better performance while towing as my truck is almost exclusively used to pull my RV.
mainly looking for insight as to the complexity of the swap, is it a straight forward bolt up deal?
do I need to replace tranny?
what other than engine needs replaced, and where can I go to find info on the swap,,,,,
anyone done this swap that can tell me their experience would also really help me out.
Thanks in advance, this is my first post on the site......
Ed
Allot of people have talked about it but I've only talk to one person that says he done it. He said it was a direct drop in and the 6.0 weiring harness plugs right in. He used a LS1edit to retuned it. The trans in it will be fine the 4L80E can hold what every a stock 8.1 can throw at it
well if I had a heeping helping of extra cash I would buy a new truck, but it seems that if it is a direct bolt up that tossin an extra 8 or 10k into a new truck wouldnt make sense. I am looking at affordability here. I am a firm believer that the easy way is to buy a new truck, easy that is if you have the money to do it. I have a 01 hd2500 cc 4x4 sb, with over 100k, on it, not exactly a high demand trade-in.....
you may laugh but what would it take to put a 8.1 in a reg cab truck 4x4 1500 with a 4.3 engine and the 5spd. I have a '99 nbs and its got like 86k on it. Still runs fine and i expect it to last for a while but it doesnt have much power after 3rd gear most of its in 1st 2nd.
Not much at all....
front suspenstion
rear suspension
new transmition/motor mounts
new wiring/PCM
new rear
new transmition
drive shaft
new instrument cluster
brake upgrades
----considering chevy didnt have the newer HD bodies in 99, you may also need....
new radiator/core support
new hood
new inner fenders
possible frame alterations, but not sure
Definately a one or two weekend job at the most...... :cheers:
Not much at all....
front suspenstion
rear suspension
new wiring/PCM
new rear
new transmition
drive shaft
brake upgrades
new hood
new inner fenders
dang sounds to me like alot. Prolly more than my truck is worth. Ill prolly just get an '98 s-10 and put a 6.0 from a silverado in it. Those trucks are real cheap sold mine last year for not much at all
    erickn520
    erickn520
  • Who's Online   5 Members, 1 Anonymous, 614 Guests (See full list)
    • I just brought home a 2020 GMC 1500 Denali.  She has 53K miles on her and I want to change out the fluids over the next few weeks.  I see the diff covers don't have drain plugs.  Any suggestions where I can pick up front and rear diff covers with drain plugs?   Thanks,   Bob
    • Well, the dealership got the compressor and installed it. Air at the vents seems nice and cold as it should be. The service manager said the repair has a two year warranty and unlimited mileage. Hopefully I don't have to use it. The dealership i went to was one where I bought my 2014 half ton silverado. In 10 years and 168k miles on the truck anything I needed done and two small recalls they were always very good to me. Not a huge dealer either. I think they treat people well because they want you to come back. I have dealt with a different dealer that was too big to care about an individual. Just my two cents.
    • Hi All, I operate my 2021 3500 SLT most of the time with the tailgate off and in a crate because I have a slide-in camper. However, at least once a year, I take the camper off and put the tailgate back on. Recently I installed the tailgate, but had a hard time getting the connector bail to swing to the fully latched position. The connector seems to fully seat, and everything works, but the bail doesn’t swing to fully latched position.  It swings almost there but stops and I am afraid to push it any harder.    Does anyone have any advice on cleaning or lubrication or anything else I should be doing?  i know how to properly operate the connector. During the time the tailgate and connector are off, i have a double plastic bag over the truck connector secured with rubber bands to keep it clean, but it still had some dust in it this time when I blew it out with compressed air. I didn’t want to spray it with anything other than air without doing some research. Thanks.
    • There are a lot of spammer's that do that, quote something and add some commentary to make it seem legit, but modify the quoted text a bunch making sure when posted it's long enough to be "click to expand", and either immediately insert a spam link, or come back after some time and edit it to add the spam link.
    • Hello @jaszr2 Do you have a link for the item? I put a replacement bumper on my truck and consequently had to relocate the shutters. I studied on them a while, and figured if you left a couple key blades, you could get most of the airflow with probably no throwing codes.
