? about Crank relearn????
i just got my wait4 me tune on my stock pcm and have herd about guys that get this crank relearn done , what is this , what advantage does it give and do i need it , also do yall think jesse removed the torque management ive herd about ,thanks guys :cheers:
Is this tune on your factory PCM? If yes, then there is no need for the relearn. The relearn is for the PCM to know exactly where the Crank is mainly for identifying which cylinder for misfire detection.
Did you request torque management removal?
A crankshaft variation relearn
must be performed if:
A diagnostic trouble code of P1336 is
present.
The computer has been replaced or
re-programmed.
The crankshaft position sensor has been
replaced.
The engine, harmonic balancer, clutch, or
flywheel have been: disassembled,
removed, or replaced.
The crankshaft position variation
learning feature enables the
computer to compensate for part
manufacturing tolerances. This allows the computer to accurately
detect an engine misfire throughout
the engine RPM range. The learning
process is stored in the computer’s
memory and does not have to be
repeated unless one or more of the
above conditions are present.
I removed mine, all of it. I wouldn't recommend it to anyone. It's all in how you drive and it can save some wear and tear on your truck, especially the transmission. I would recommend about a 70% reduction.
