Dual exhaust/maintain stock back pressure?
I have an 06 GMC 1500, 5.3 and would like to replace the stock muffler with something (muffler/duals) that would give a mild rumble at idle, no resonance at crusing speed, yet maintain the same back pressure as the stock muffler, (don't want to loose any power on the bottom end). Suggestions/recommendations would be appreciated.
i changed to a flowmaster on my 06 5.3 and it wont even spin a tire from a dead stop now....before it would smoke them....im going to change it back to stock.will yours smoke the tires?mine is 5.3 auto with 373 gears and posi.....regular cab short bed.
What you want is the Magnaflow that I have in my sig.
I just went to the local muffler shop and got a quote for Magnaflow... $300. They cut at the end of the stainless steel stock pipe and install a magnaflow muffler and pipe it back. now I just have to talk the wife into it. :chevy:
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
