98 GMC Jimmy power loss
I have a 98 GMC Jimmy and around 60ish the car completely dies like it's having trouble turning the block over. It also does this when going up an incline in any gear. It also dies if I pull off from a light sometimes droping to about 100rpm and sputting then going fine. Just started today. I tryed checking codes but can't find a site with a list. I'm totally lost. The ainto lock break symbol comes on and the e-brake engaged symbol. I checked my brake fluid as suggested by a fellow gm owner and It's full but the break fuild is blackish but brakes work fine. :chevy:
Around here, AutoZone, Oreally's, and PepBoys will read your codes for free.
What you're describing could be a hundred different things.
First impulses...I'd say fuel pump, sensor (02/knock) problems, or even bad cats.
Is there a way for me to check codes without a diagnostic machine. My friend was talking about me ground A and B port with a paper clip or something. How does this work.
That system is way too old for your truck. Pre-1996, you could pop a paperclip into the diagnostic port, and count the number of times the SES light would flash. This is not the case anymore. You need a codereader.
Autozone does them for free. Just go in and say "I need some codes read" ...its really not even a big deal for them.
Walmart has ODBII Code Readers...i bought a simple one for $59.99...i use it all the time...love the little thing.
    ballencd
    ballencd
  • Who's Online   5 Members, 1 Anonymous, 654 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
