Pioneer AVIC-Z1
I'm thinking to installing one in my 06 Silverado. The whole install will include the AVIC-Z1, the 6 Disk in dash DVD Changer (XDV-P6), Bluetooth, IPod, XM, XM Traffic, Rearview Camera, and Onstar-RAP-Stearing Wheel control integration.
I was wondering if anyone has any experience with these components and if you have any thoughts/comments. The two specific questions that I can think of are, will I be able to use the factory XM antenna with the Pioneer unit (GEX-P10XMT), and does anyone have a color rearview camera that they would recommend? Pioneer has one (ND-BC1 but it looks a little bulky.
I will also add an amp, swap out the speakers, and add a subwoofer behind the rear seat. Lastly I am thinking of adding headrest monitors to provide video for the kiddies in the back seat. I currently have no preference and would like to know who is happy with the components that they have.
I've got the AVIC-D1 and use the ND-BC1, the steering wheel interface with the factory controls, XM, Nav, iPod interface and TV Tuner. I loop it all back through the overhead DVD and visa-versa so you can see DVD's on the AVIC as well as being able to see TV and Nav on the factor overhead screens in my 2006 Tahoe.
I use the ND-BC1 camera and it works amazingly in low light conditions. It's a very good camera.
  • 1 month later...
I have the AVIC-N2 in my Z with all the "extras" that go with it - Nice unit
Unless you live in NYC, LA or tend to visit such areas frequently - forget about the XM Traffic - save your $$'s. I travel frequently & have not had it "help" as I'm not in their "area".
I've been told that the Z-1 is even a better unit than the N-2 so enjoy!
I have the z-1 and it is a great unit, with lots of features. I hear pioneer is going to come out with a better unit soon. It fits fine in my 2005 silverado, I just had to break some of the stock supports behind the head unit. If you have the newer style headunit, which I think 2003 does, you should be good. avic411.com is a good source on the unit itself. Hope this helps.
    rayredbone
    rayredbone
  • Who's Online   0 Members, 0 Anonymous, 509 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
