Tremec T-56 in first gen S-10
hey i have a chance to get a hold of a Tremec T-56 ^-speed tranny but will it fit in a 1989 S-10 2wd 5-speed 4 banger
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
