Oil Capacity of 4.8 engine 2006
mountainbiker
Just got this new 2006 K1500 with the small 4.8 v8 engine, How much oil does this thing hold, 5 quarts? Also, is there any website that has all the "capacities" on it, oil, gas tank, water, etc. The dealer salesman could answer these quesctions, thanks for any and all replys.
Capacities - Approximate Fluid
See Fluid and Lubricant Recommendations for more information. All capacities are approximate. When adding, be sure to fill to the approximate level, as recommended in this manual. Recheck fluid level after filling.
Application
Specifications
Metric
English
Axle Capacities
Front Drive Axle (8.25")
1.43 liters
1.51 quarts
Front Drive Axle (9.25")
1.73 liters
1.83 quarts
Rear Drive Axle (8.6")
2.03 liters
2.15 quarts
Rear Drive Axle (9.5")
2.6 liters
2.75 quarts
Rear Drive Axle (9.75")
2.84 liters
3.00 quarts
Rear Drive Axle (10.5")
2.6 liters
2.75 quarts
Rear Drive Axle (11.5")
3.0 liters
3.17 quarts
Cooling System
VORTEC 4300 V6 Automatic with Front A/C*
14.0 liters
14.8 quarts
VORTEC 4300 V6 Automatic with Front A/C**
15.6 liters
16.5 quarts
VORTEC 4300 V6 Manual with Front A/C*
14.3 liters
15.1 quarts
VORTEC 4300 V6 Manual with Front A/C**
15.7 liters
16.6 quarts
VORTEC 4800 V8 Automatic with Front A/C*
14.4 liters
15.2 quarts
VORTEC 4800 V8 Automatic with Front A/C**
15.9 liters
16.8 quarts
VORTEC 4800 V8 Manual with Front A/C*
14.7 liters
15.5 quarts
VORTEC 4800 V8 Manual with Front A/C**
16.1 liters
17.0 quarts
VORTEC 5300 V8 Automatic with Front A/C*
14.4 liters
15.2 quarts
VORTEC 5300 V8 Automatic with Front A/C**
15.9 liters
16.8 quarts
VORTEC 6000 V8 Automatic*
15.3 liters
16.2 quarts
VORTEC 6000 V8 Automatic**
15.8 liters
16.7 quarts
VORTEC 6000 V8 Manual*
15.8 liters
16.7 quarts
VORTEC 6000 V8 Manual**
15.8 liters
16.7 quarts
VORTEC 8100 V8 Automatic*
25.5 liters
26.9 quarts
VORTEC 8100 V8 Automatic**
VORTEC 8100 V8 HD Automatic*
23.7 liters
25.0 quarts
RPO L18 VORTEC 8100 V8 Manual*
25.6 liters
27.1 quarts
Lubrication System
6.6L (RPO LLY) Oil Capacity-with Filter
9.5 liters
10.0 quarts
6.6L (RPO LLY) Oil Capacity-without Filter
8.7 liters
9.2 quarts
Engine Oil with Filter
4300 V6
4.3 liters
4.5 quarts
(RPO LU3) 4800 V8; 5.3 V8; 6000 V8
5.7 liters
6.0 quarts
(RPO LM7, L33, L59, LR4, LQ4, LQ9) 8100 V8
6.1 liters
6.5 quarts
Fuel Tank
Short Bed and 2500 LD
98 liters
26 gallons
Long Bed and Chassis Cab (Pickup Box Delete)
136 liters
36 gallons
Chassis Cab 3500 and 3500HD - Front
102 liters
27 gallons
Chassis Cab 3500 and 3500HD - Rear
87 liters
23 gallons
Transfer Case
New Venture Gear 149 (NP3)
2.1 liters
2.22 quarts
New Venture Gear 246 (NP8)
1.9 liters
2.0 quarts
New Venture Gear 261 (NP2)
1.9 liters
2.0 quarts
New Venture Gear 263 (NP1)
1.9 liters
2.0 quarts
Transmission
4L60-E 4 Spd. HMD Auto Pan Removal
4.7 liters
5.0 quarts
4L60-E 4 Spd. HMD Auto (M30) After Complete Overhaul
10.6 liters
11.2 quarts
4L80-E Auto (MT1)
7.3 liters
7.7 quarts
4L80-E Auto (MT1) After Complete Overhaul
12.8 liters
13.5 quarts
5-Spd. Auto Allison (M74) Fluid and Filter Change
7.0 liters
7.4 quarts
5-Spd. Auto Allison (M74) After Complete Overhaul
12.0 liters
12.7 quarts
New Venture Gear 3500 Manual Transmission
2.3 liters
2.4 quarts
New Venture Gear 4500 Manual Transmission
3.8 liters
4.0 quarts
6-Spd. Manual (ZF) (ML6)
6.0 liters
6.3 quarts
* Engine Fan Driven cooling system
** Electric Cooling Fan system
If you go to www.mygmlink.com you can register your vehicle there. One thing that it also does is let you look at an online owners manual in PDF format.
Plus it lets you know about recalls and services.
    ballencd
    ballencd
  • Who's Online   3 Members, 0 Anonymous, 455 Guests (See full list)
