93 Yukon Swaying
What's up? I have a 1993 GMC Yukon 2 Dr 4x4. I purchused it with the original tires and wheels on it and the truck would sway in the rear when it got above the speedometer limit (85 mph), but the speedometer was off. So I change the tires to some 305 tires on the same wheels to correct for the speedometer error. When I had the tires put on I had them balanced. I was told that one of the wheels may be bent because the could balance it with all the weights they put in. That wheel and tire still ended up in the rear of the Yukon. Now when I hit 70 mph the truck starts swaying really bad. I was wondering if that off balance wheel could be causing the problem.
This truck was not taken care of by the previous owner, but it had a strong motor and at $1000 it was a deal .
The leaf springs are bad too. The rear left side is almost straight and the right side rear isn't far behind. I was also wondering if the leaf springs from a newer truck could fit them. I called the dealer and they told me that this yukon should have come with 5 leaves on each spring but this one has only four. They also told me that the springs are special order and are over $400. I can get the leaf springs from newer trucks at the local boneyards and for half the price.
Thanx alot for you.
I'd say that the springs are your "swaying" problem.
Start there anyway...If the truck has been abused, there's no telling what could be wrong back there.
I must add....DAAAAAYUM, $1000 is a good deal on one of those.
Yeah I caught the guy on a bind and the truck is pretty abused on the outside and inside...But nothing I can't fix...I'm pretty good at the mechanical work so that wont be a problem.
