Inner wheel step sides
Has anyone had the inner wheel of the NBS step sides break? Mine look like a roch shattered a windshield on both sides.
I don't suppose someone knows the replacement part numbers too?
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
