99 5.7 TBI yukon backfires
We have a 99 yukon with the 5.7 TBI engine. it starts fine when cold, and runs great when hot or cold, but when its hot and you cut it off and let it sit for about 30 minutes and go to start it, it immediatly backfires once. If you cut it off and restart withing several minutes, no problem. Had my wife start it once, while I looked, there is a strong oil smoke (not a gassy smell) expelled from the air intake at the TBI. It looked to be coming from under the air box/chamber, but when I removed it, there really did not look like anything back there would be the cause. (was the backfire just pushing teh air intake off teh rubber gasket and blowing the smoke out?) It has the stock air filter (no K&N oil in intake) and no modifications. I had the computer read @ Advance and no codes. What little I know, it's pointing to a EGR that has gone bad, but for 150.00 I don't want to start the part replacement game.
Usually backfiring is from an excess amout of fuel so mabey the fuel pressure regulator is bad not holding pressure and letting the fuel build up after a while and i think the reason this is not happening after a short amout of time is because the fuel does not have enough time to build up and starts up fine could also be injectors just a guess hope you figure it out
    ballencd
    ballencd
  • Who's Online   4 Members, 1 Anonymous, 595 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
