kind of weird - panel lights out
Z71jobert
my cousin has a 2001 silverado and the dash lights have gone out. some lights, such as the radio lights and the illumination aroung the a/c controls still lights up as well as certain signals and indicators in the gauge panel. BUT, the actual lights behind the gauges are out. the gauges still operate properly and the information panel (cargo light on, low washer fluid, etc.) still operates. the only problem is the lighting. we have pulled all the fuses and replaced even some that were not busted just to make sure.
any suggetsions?
thanks.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
