Steering Noise
While I'm driving and steer either left or right, I can usually hear the Steering Pump make hissing noises in the cab (so you know it's louder outside the cab). It is the same noise it makes if you turn the wheel all the way to the left or right, and hold it there.
Is this a sign of something going wrong, or is it normal.
I have an '04 4x2 LT Crew with 17,500 miles on it.
Well, its not normal. Now whether or not its a damaging problem, that depends. I assume you've checked the fluid and steering shaft?
The fluids all look good and I have had the intermediate steering shaft replaced by my dealer 10,000 miles ago (steering clunk). This appeared about 2 months ago or so. It hasn't got worse or any better, so at least it's not escalating. It usually only happens after the truck is warmed up and only on certain steering manuvers.
It's very strange.
  • 6 months later...
I have this same symptom on my (new) 99 Tahoe..did you ever get a diagnosis..or did it ever get worse?
Steering is quiet in a straight line..but turn the slightest bit off the centerline and and the PS starts to hiss or psshhh a bit until you turn back to center...
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 716 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
