Westers Custom Tuning On Sale!
We're offering 10% off Westers Custom Tuning orders that are placed through Sunday evening (7/2)! This tuning is done specifically for your vehicle.
BENEFITS:
Lifetime warranty (no cost or fees)
Lifetime updates for all future mods ($45 shipping and handling fee)
Lifetime full price paid credit toward your next custom tune for your next vehicle ($45 shipping and handling fee)
No vehicle downtime! You will receive your recalibrated PCM before sending your core back. Want to upgrade this for other mods in the future? No downtime here either! The same thing can be done for this too.
HORSEPOWER GAINS:
Customers have been seeing about 24-34hp from the 5.3 28-50hp from the 6.0 and 25-55 horsepower from the 8.1 motor. The spread depends on how aggressive the tuning is along with other modifications that are done to the vehicle. Fine tuning for other mods will sometimes make more of a different than just running those with the stock programming.
Detailed info can be seen in the Truck Ignition section of our website.
Orders can be placed online or by calling 1-877-482-9763. We will e-mail you a custom order form after your order is placed. We will take an authorization for the core amount (not an actual charge). This will be dropped when you send your core back in the alotted time frame. Some late model cores are not available so you might need to send your vehicle's PCM in to be programmed.
Have a good day!
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
