Hotchkis front sway bar 99+ 2wd $100
New Hotchkis front sway bar for 1999 and newer Silverado and Sierra 2wd (coil front spring suspension) trucks. The bar is 1 1/2" diameter and comes with new bushings. Your will need to buy the mounting brackets and end links from Hotchkis to complete the kit. Total cost $100, plus shipping.
(I bought the wrong bar, that is why I am selling it.)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
