Windshield washer problem?
Allright i need the help from some of yall with newer trucks
When i go to spray wiper fluid it kinds just drizzles it out about 5in above the wipers it only works kinda allright if im flying down the highway this doesnt seem right, but i cant remember when it did so yall please set me strait and if anyone knows what this might be bad motor etc please let me know thanks a lot
It's only been about 3 hours man, give folks a day or two to read and reply.:cheers:
Does the fluid come out of the wipers, or are there seperate sprayers down on the cowl (I can't remember)?
out of the wipers i was just frustrated looking at all the stuff im about to have to fix $$$$$ well at least its finally paid for that and there was like 100 users on and 15 people had checked it out haha oh well i pulled the tubes off and there didnt seem to be anything obstructing flow i thought i saw something on here part # or part recently but searched it and nothing even went through about 50 pages any help would be appreciated
check the obvious stuff first. Clogged outlets, crap in the fluid, kink or obstruction in the tubing, leak in tubing, etc.
Get a piece of piano wire, and try cleaning the nozzles by poking the wire through them.
As far as 15 people seeing it and not replying, the forum has over 26,000 members. Those 15 people make up about 1/20th of a percent of the forum members.
:cheers:
the plastic trim piece in front of the windshield removes easily revealing the tubing. clean and blow out with low pressure air. pump is centrifugal so will flow air backwards ok. Just remove filler cap. fixed mine in 10 minutes.
Ken
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,155 Guests (See full list)
