A/C blows hot and cold
The left temp actuator is out of whack. When the control head can't get a proper reading from it, it drives it to the default position, which is full hot.
You could try disconnecting the battery for a minute or two, reconnect and start the truck. DON'T TOUCH the a/c controls for at least a minute while it goes through it's reinitilization routine. That *may* get the control head to relearn the left actuator, though there may be a permanent fault.
