wait4metune
So, I know that I can get better mileage and more power on 93 - but will the mileage boost offset the increased cost in mileage or not?
My truck currently gets a pretty solid average of 19 mpg. (I drive like a granny :banghead:)
Other stuff I want:
Firmer shifts (if its good for the tranny?)
Some amount of TM gone - what percentage do you all recommend? 50%?
Tow/Haul mode left totally alone - Need to tow ~3000 lbs now and again.
What else should I ask for?
Thanks for the opinions!
I have the westers but im sure they are somewhat close i have the 89/93 tune with "almost all" of the tq mgt out the shifts were medium firm, which was perfect probably my favorite thing about it anyhow im getting better milage with 89 than my 93 i dont know why but hand calculated 89's doing better like i said the firmer shifts is what i liked most i was scared it was going to shift like a shift kit, but you can barely tell its shifting without watching the tach very fast shifts compared to stock wish i would have done this along time ago it will give your tranny alot more life
On my tune I told Jesse to improve the towing in tow haul. He did just that, engine really grunts and I had him raise the shift points, it wont even go into OD until you reach atleast 65 mpg. Also I notice on a duplicate trip, same load and destination with close weather conditions, I went from 10.1 mpg to 12 mpg with Jesse's tune. Im really happy with it. To bad the support sucks
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,193 Guests (See full list)
