Hard Starting
I have the 4.8L 00 silverado and i have a starting problem that i couldn't find by searching. anyway my truck won't start until the 3rd time i try the key. i can crank it over for as long as i want the first time and it won't start it will just keep turning over. sometimes it will go on the second try but it will run like crap for a little while and then will be fine. usually it will pop right off on the third try and run fine. there are no other problems with the truck besides this. any suggestions?
  • 3 months later...
I have the exact same problem except my truck is a 2000 GMC Sierra 1500 with a 4.3. If you find the answer I would like to know,
Thanks
Thanks
I found my problem changed out the fuel pump spliced in a new harness and truck is cranking like it did when it was new.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,193 Guests (See full list)
