tires and rims info needed
SInce i dont hardly take my truck off road unless to drive out to go dirt bike riding i was thinking about gettin some nice 20in rims, no bigger, i dont like them to much bigger. i was wondering what a good size tire would go well on these rims and be wide but not to wide till where it looks like a mexican ride(no offense intended, just dont want it to look like that) and fill up the wheel wells perfectly, maybe some 305 50 r20? any one got any pics of theres? even with 22's or 18s just need to see how the tire looks and would like to kno if they ride well? i do a ton of driving and the stockers kinda suck, screach around corners at full crank and just feel unstable at high speeds. im willing to crank the torsions a little if i have to, i want it to be level anyways. also what is a good off set to get onthe rims? i really dont want them stick way out to the sides but maybe like 1/4 to 1/2 in. i also dont get how these metric tire sizes work at all, confuse the hell out of me. any info would be great, and pictures would really make my day, i want to see what i want to get beforei get them and have them put on then have to piss off the tire guys and tell them to take them off cause they are to small or two wide or both you kno? thanks
--David
i am running 275 60 on 20s. they clear on my stock height 4wheel drive sierra. i thought i was going to have to do a torsion bar crank but i didnt need to. it also gives it a visual of leveling it out front to back because it fills in the wheel wells a little more. i am sure the 305 50s would fit but they are a little smaller in diameter and wont fill out the wheel well as much, but if you are trying to go wider that might be the look you are going for
you have a pic of your truck dingus, i woudl love to see how they fit, really looking for some pics to check out before i end up with a set of tires and rims that look gay on mine and i have to explain to the tire place to take them back off cause i dont like em you kno? thanks
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
