1999 Silverado 1500 rclb 4x4
1999 Chevrolet Silverado 1500 4x4
Vin: 1GCEK14V0XE142812
99,712 miles
Regular Cab Long Bed Base model
Summit White with Graphite interior
4.8L V8 automatic with floor mounted shifter
PS, PB, AC, Tilt wheel, solar ray tinted windows
MW, ML, vinyl bench seat with rubber floors
NADA lists truck's retaill @ $10,800
Asking $7,300
This is a government vehicle that has had all services performed on it at the designated schedules. Very strong engine and transmission, i.e. no slipping. Very little if any towing was done with the truck. Cold AC, everything works, drove truck 1100 miles without any issues, starts every time. Original owners manual and window sticker are present. There are a couple of small dents underneath the truck that are hard to see unless you look for them (they are in the rocker). The back bumper is also dented on the left side. Otherwise it's a great work truck. Any questions feel free to PM or e-mail at [email protected].
Pics:
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 716 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
