Please help, 99 yukon died on highway
hey guys, i did a bunch of searching but unable to narrow down my problem.
tonight, driving home from work my 99 yukon just died... i was doing about 65mph on the freeway and it started to slow down, noticed the rpm was zero and i had my foot down on the gas pedal, it sputtered a bit, as if i was running out of gas. pulled to the side, it would crank but wont fire up. so towed it home and i went to start the truck again and it fires right up! didnt drive it around because i'm scared it'll die again.
i should also mention that i got the SES light a couple months ago... it flashed, then stayed on steady, then went away, came back on again when i really load up the truck... climbing hill, towing, will always trigger the SES.
and ever since the SES has been coming on... the truck sputters and hesitates a bit climbing incline at freeway speeds in OD. idle is rough at times.
the fuel filter was changed about 15k miles ago, i just changed the plugs. when i turn the key to ON position i can hear the fuel pump whine on briefly. i'm guessing it's not the fuel pump because it started up again several hours after it died on the freeway? i know i should read the codes... i need to get a scanner.
can anyone please help? thanks a lot everyone!
First thing i would check is to see if your getting fuel, because imo it sounds alot your like your fuel pump just took a dump.
-edit-Maybe i should of read your entire post first sorry :thumbs::banghead::banghead:
I had a 2000 Yukon Denali, same body as the 1999 with the 5.7L vortec do this to me. What my problem ended up being was a loose distributor cap, that ended up melting itself. Once htis was fixed, it was good to go again.
Check the Distributor to see what it looks like. It is a real Pain to get to, but its a very cheap fix if this is the problem.
Hope it helps.
Bryan
Hope it helps.
Bryan
you know, just recently i had the engine jacked up a bit to do a oil pan change out... and what i noticed was the engine had to be jacked up quite a bit and the dist cap towards the firewall seemed to be really close to the firewall there, i was concerned about it actually but didnt think it was knocked loose or damaged, but this is a good idea to check!
my question is though... if i did knock the dist cap loose during the engine jacking ordeal for the oil pan, and if being loose the cap melted, would the truck start right up again after a few hours of sitting? i tried starting it again this morning, and even after sitting over night she fires right up as if nothing ever happened. :banghead: i was tempted to drive it to work but instead hitched a ride... thanks.
any more comments please? thanks!
Almost sounds like fuel pump to me. We have a lot of chevies at work and every one now has dumped a fuel pump. Usually happens on a hot day. Truck just sputters and dies on the road. If you wait 20 minutes or so it fires right up again, and may be good for a while. Turns out his has been a common problem for a lot of GM vehicles. I read a lot about it on another forum. My dad had the same problem with his 04 1500 silverado. Truck was fine around town, but on the highway there was a long haul up the mountain, and during a hot day the thing would die on him. He'd wait a bit and the truck fires up like nothing happened. he'd go 20 miles or so then it would happen again. The dealer told him they had replaced a lot pumps already
My 99 Sub had the pump changed 2 years ago after it died in the driveway and again this winter it went. This time the engine died on the highway. It started again after I had pulled over to the side of the highway. The next 50 miles on the way home it hesitated a few times. The next few days the truck was harder to start so I suspected the pump again. First thing I did to rule out the pump was do a pressure test . Bingo fuel pressure was borderline so if it droped a few psi it would hesitate or stop running. All that said I replaced the fuel pump but this time no OEM part. Found a replacement pump from VENOM PERFORMACE Inc. which runs qiet, cooler and more output. I can stand next to the truck while pump is running and can hardly hear it. Pump was cheaper then OEM part by the way.
Cheers
John
thanks for the help guys... i havent had time to take a closer look at it but this morning she fired right up again.
but i didnt drive it to work, i hitched a ride with my wife in her 1988 honda civic that's still on the original fuel pump. i hate that d**n civic but at least it runs.
i'm going to autozone tonight to pick up a code reader (i've had SES light on for a while now too).
how much work is it to drop the fuel tank and replace that d**n pump?
Since it was winter and -20f outside I did mine at my mechanics shop with him. We had the pump replaced within 2hrs but I had only 6 or 7 gal. of gas in it and it's a 40 gal. (US) tank. It's a lot easier on a lift and with a support jack for the tank at a garage. But you need to read your code first in case it's not your problem. good luck.
Cheers
John
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
