How to remove steering wheel
stebob
I did a search and unfortunately, don't have a ton of time to spend, but I didn't see exactly what I was looking for. I'm hoping someone can help me. I have to replace the multi-switch (turn signal) in the column of my '97 Z71. It appears I have to remove the wheel to do this. I'm concerned and somewhat nervous about the air bag. I was wondering if removing the wheel on my '97 is the same as this: http://autowoods.com/installation_guide.htm
Thanks for any feedback!
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
