Shock Recommendation
My 2001 2500HD 4X4 Crew Cab 8.1L is in need of new shocks.
What shocks would you folks recommend? I don't go off-roading.
The truck tends to buck like a mule in the rear and the rear shutters when hitting a bump. Is there a particular shock that will help with this condition?
Thanks a million for any advice!!
I know this question came up recently, so you should do a search.
I like Bilsteins, I replaced the stock shocks on my truck, and it smoothed the ride a lot, both loaded and unloaded.
Thanks Getmore!
Do you remember what model Bilsteins you purchased?
I replaced with stock replacement Bilsteins. The buckboard feel of the back on the highway is much improved, the front rides noticeably harsher but not terrible. They have eased up a bit with mileage. If I had to do it again I would have just replaced the rears with the Bilsteins.
Front : F4-BE5-6081 HD
Rear : F4-BE5-6082 HD
DEWFPO
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 750 Guests (See full list)
