Crossmember Question
tonyt915
was told that a crossmember from a corvette will fit on my 03 silverado and will give me several more inches of clearence is this true also what year crossmember?
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
