Now the DIC doesn't work
robertsofthehill
2004 Chevrolet Suburban. Husband is a Gen'l Mgr of truck dealership providing service and sales on large trucks. Prior mechanic for 17+ yrs so he's definately got some "know how" but not familiar with Chevy Suburbans and we need help.
History: first received interim messages on DIC of Instability System Disabled. Message would remain on for approx. 1 min and go off and might occur every 4th day or so. Began going off more often (sometimes daily) with the message staying on for longer periods of time.
During this period of time, the speedometer stopped working and while we ordered the part and awaited it's arrival, we assumed the message may be due to the speedometer. We really didn't really place a high priority on looking too deep into it after we checked the main systems out and saw all was ok ( fluid levels, etc.) Had a lot going on at the time.
Part came in, husband replaced cluster. Nice to have working speedometer again.
Now DIC on steering wheel does not work. Volume, seek, etc works but DIC does not. To top that off, just the other day "INSTABILITY SYSTEM DISABLED". This time the message appeared and stayed on the rest of my drive home. Probably thirty minutes or so.
I hope you can offer some insite. I hate to send this to our dealership. Would you believe this all started happening at about 37,000 miles. We purchased the car used at about 32,000 miles. It figures! :ughdance:
The new cluster needs to be programmed. Was it?
Stability system problem is unrelated to the speedo problem. As to what's wrong... who knows. Need the codes that set for starters.
My husband says when we ordered it we provided our current mileage. Would/should that have included the programming you are referring to?
No, setting the mileage has nothing to do with the calibrations that are programmed into the cluster to match your vehicle and its options. It needs to be programmed.
